Timing
Old Jul 25, 2008 | 09:07 PM
66MuStAnG4sho's Avatar
66MuStAnG4sho
Default Timing
Can anyone point me to where i can learn how to time my 66 mustang? it has a 68's 302 2V in it. I tried searching the forums but it came up saying no results. Any help would be appreciated. Thanks.
Old Jul 25, 2008 | 11:21 PM
photocliff's Avatar
photocliff
Default RE: Timing
I can help you if you live close to me. I am In Sandy, Utah
Old Jul 25, 2008 | 11:30 PM
ky's Avatar
ky
America ftw
Default RE: Timing
hes in new mexico.
that wont do.
the search function is broken due to recent hacks. i can physically time a engine but i cant put it in words. hopefully someone smarter than me will answer this.
Old Jul 26, 2008 | 05:16 AM
kalli's Avatar
kalli
Default RE: Timing
factory shop manual says 8 degrees before TDC at idle, vacuum disconnected and plugged (so that the carb does not suck air through your hose while you do that)
the max advance (centrifugal advance without vacuum) should be around 32-35 max at 3200 as far as I know.
most people set timing at 10 or even 12 at idle as it runs better. Mine runs better with 10 than 12
when you feel your starter does rather a whop-whop-whop than a whopwopwop you might be too far advanced
obviously you will need a timing light to set this
If you still run points in your distributor you will have to adjust them first as they have affect on timing and spark.
When finished re-check timing with vacuum hose connected it should not change. if it does you might have the wrong port on carb for vacuum pickup.
if you have that set, and you still suspect the timing could be wrong, then obviopusly check plugs and leads.
Furthermore a slipped harmonic balancer might cause to show you wrong timing marks
Old Jul 26, 2008 | 03:09 PM
66MuStAnG4sho
Default RE: Timing
k thanks everybody. I'm hoping to get up early enough tomorrow to do this. I really miss driving Roxxanne. Right now I'm stuck driving a 90 Honda...it's just not the same! I have a Haynes manual, but its not very helpful to me.
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
