electrical problems
Old Jul 26, 2008 | 07:16 PM
nmdjr's Avatar
nmdjr
Default electrical problems
Hi,can anyone help i just installed a 351cleveland in a 70 mach 1. my problem is I've installed a new distributor/coil wires everything. When I crank it I'm getting an electric arch between my power steering line and shock tower.When I disconnect the leads to the coil(ignition and lead from distributor) the arch goes away. Could i have my coil leads backwards also the coil I got says use only resistorprinted on the coil.where is the resistor? as far as I know the wiring is stock. never seen this before I'm sure its somethimg simple but not real fluent with electrical issues. Thanks Norm
Old Jul 26, 2008 | 08:29 PM
67 evil eleanor's Avatar
67 evil eleanor
Default RE: electrical problems
It may be that the engine is not grounded good and its jumping. Check the strap and/or wire and their connectors for a bad ground. This can be easily done by removing them and cleaning them with a wire brush.
jma2
Jul 10, 2023 01:00 AM
ak98
Feb 18, 2023 08:36 AM
uberstang1
Sep 20, 2015 06:42 PM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
