What Is It???
Old Jul 26, 2008 | 07:16 PM
unit91's Avatar
unit91
Default What Is It???
This switch is in my 68 convertible. What is it? Not in Ford parts manual diagram.
[IMG]local://upfiles/52841/2DF334BCA72143929A4F58F880D8B68F.jpg[/IMG]
[IMG]local://upfiles/52841/EA0012DCC5A14E38B0C1E022DE8F77E5.jpg[/IMG]
Old Jul 26, 2008 | 07:49 PM
65Coupester's Avatar
65Coupester
Default RE: What Is It???
Looks like a brake light switch.
Maybe some kind of kludge repair.
If the brake lights work, then disconnect 1 wire. If they stop working then that is it. Or short the 2 wires together and see if the brake lights come on.
Is there a switch on the pedal?
Old Jul 26, 2008 | 09:14 PM
flyingfool's Avatar
flyingfool
odd, never seen one of those. mabeye its for a brake pressure warning light?
Old Jul 26, 2008 | 09:35 PM
unit91's Avatar
unit91
There's a stoplight switch on the brake pedal. If I disconnect the switch in the phoho my brake lights still work (although when I turn the turn signals on the brake lights go out).
Old Jul 26, 2008 | 09:43 PM
davesanborn's Avatar
davesanborn
It's not a brake light switch. It's likely an improvised "low brake pressure" switch. These switches are normally on the distribution block. It's designed so that when you step on the brake pedal and it goes to the floor and the car doesn't stop, it'll illuminate an instrument cluster idiot light. You probably won't ned the light to tell you that you have no brake pressure as you smash into the car in front of you.... thus, idiot light.
Dave
Old Jul 26, 2008 | 10:55 PM
vineman's Avatar
vineman
Im not doubting Dave at all but i have seen a brake light switch that runs off the lines themselves that looks just like that thing, minus the crud and muck layer.
Old Jul 27, 2008 | 09:42 AM
kalli's Avatar
kalli
i had a brake ligh tswitch that looked exactly like this but was bolted to the master cylinder.
give it a try. check if your brake lights work. if they do unplug this thing and see if they still do
plug them back in and disconnect the cables at pedal
so you see which of those actually works the light
Old Jul 27, 2008 | 11:43 AM
tncruiser's Avatar
tncruiser
thats the way they used to wire stoplight switches it looks just like what was on my 56 ford
Old Jul 27, 2008 | 12:13 PM
kalli's Avatar
kalli
mayb ethe one on pedal didn't work, it was too much hassle to replace adjust, so the PO decided to go the hydraulic switch route .. who knows ... it's def not original and it's def a stoplightswitch
if it works or if it's even iin use you will have to find out
Old Jul 27, 2008 | 12:16 PM
Starfury's Avatar
Starfury
Yes, it is some sort of hodgepodge stop light switch (not a low pressure switch)....but I don't know why it's there. The low pressure switch is actually a mechanical switch (not hydraulic, since the system is at zero pressure when the pedal isn't being pressed)partially built into the distribution block, and can be seen sitting on top of it on the right side of the picture.
