engine combo sound strong?
Old Jul 27, 2008 | 10:06 PM
racin66coupe's Avatar
racin66coupe
Default engine combo sound strong?
about a engine combo for the 66 once i get to that point. its a 351w
stock bore and cleaning it up (ofcourse if it is salvageable)
stock crank
stock rods (arp bolts)
then some dished forged pistons
world windsor sr heads
rpm air gap intake
blow through carb
lunati cam (1800-6200rpm) good choice?
msd ign etc etc
and a pair of midsize turboes off of some sort or diesel.
does it sound like itd be a strong combo? im trying to keep it on the cheap here
any suggestions greatly apprecitated
hows it sound
Old Jul 28, 2008 | 12:18 PM
racin66coupe
Default RE: engine combo sound strong?
anyone?
Old Jul 28, 2008 | 12:25 PM
1slow67's Avatar
1slow67
ROTM Moderator
You could use the T3 Turbo. Those were used on the SVO mustangs.
Old Jul 28, 2008 | 03:29 PM
zggill04's Avatar
zggill04
I'd be careful trying to run a TT setup (twin turbo) with a fairly stock bottom end. That looks like your going to make it your weak point, and running too high of boost will eventually shoot a rod out of your oil pan or possible ruin your top end. What are the specs on that cam? With a turbo set up you don't have to go with anything to radical. I'd venture to say about low to mid 400hp to the rear wheel done right and depending on the numbers of the cam and heads.
Old Jul 28, 2008 | 05:01 PM
racin66coupe
well i know the stock crank is very strong (i wanna say like mid 500hp? i heard) and the rods should be ok with arp bolts. and it will all be balanced too.
to be honest, i dont know the specs on that cam, i was basicly just throwing a cam out there[&:]
isnt the t3 a small turbo?
Old Jul 28, 2008 | 05:12 PM
SalikDDD's Avatar
SalikDDD
i got a T66 off the supra but i'm not about to try that on my new 331 when it comes in, i was going to remote mount a turbo to the rear and use the pipe as the intercooler kinda like STS but i dunno.
for your combo the stock crank and such.. meh.. 500-550.. block will give up before that :|
Old Jul 28, 2008 | 05:14 PM
racin66coupe
are you saying id get 500-550? or what they will hold?
Old Jul 28, 2008 | 06:48 PM
SalikDDD's Avatar
SalikDDD
they'd hold 500-550 crank apparently before the block actually gives out, not the crank itself. though.. we've had a few last on stock cranks at over 600 but that's with a mexican block
Old Jul 28, 2008 | 06:56 PM
1slow67's Avatar
1slow67
ROTM Moderator
ORIGINAL: racin66coupe
I'm not sure. That is what I am getting for my 67 though.
Old Jul 28, 2008 | 07:38 PM
zggill04's Avatar
zggill04
If that's the case about the crank then you shouldn't have a problem. I would personally just run a bigger single ball bearing turbo, unless you want the power down low then I would go with two smaller ones.
