weird squeak
Old Aug 2, 2008 | 08:27 PM
winfieldjuggalo's Avatar
winfieldjuggalo
Default weird squeak
just removed the coil springs and replaced the spring seats in my 66 coupe (289,c4,drum brakes). got it all put back together. i took it for a test drive and for the first block ortwo it was fine. all of the sudden it started squeaking fairly loudly. i really couldn't tell where it was coming from. after about 60 seconds the squeaking stopped, then i turned the corner it started again. so i go home and a buddy shows up. i take him out to hear this squeak and it only squeaks once, very breifly and way quieter than before. he probbably thinks im paranoid now but anyway, is this sounding familiar to anyone.
thanks
Old Aug 2, 2008 | 08:31 PM
davesanborn's Avatar
davesanborn
Default RE: weird squeak
It'll break-in, drive it for awhile. (inspect everything first to make sure you didn't screw something up) These squeeks usually go away after everything settles into place.
Dave
Old Aug 13, 2008 | 05:18 PM
winfieldjuggalo
Default new info
ok... heres the latest... the squeak has not gone away so it took the wheels off to take another look. come to find out the upper control arm bushings are worn out. takes some muscle but you can shake it a little bit if you try. could this be the problem? im not looking forward to removing those springs again!
Old Aug 13, 2008 | 06:02 PM
greystallion66's Avatar
greystallion66
I had a similar issue with my 66 coupe. There ended up being a very very small hairline crack in the shock tower and that was causing the noise. Got it welded up and it rides nice an quiet now.
Old Aug 14, 2008 | 04:20 AM
kalli's Avatar
kalli
it's fairly common for 64-66 stangs to speak like mad when the bushings dry out.
Try if you can hear it already if you push the front down (like as when you are testing springs). There is a grease nipple at the UCA that is impossible to get to. But try with some WD40 first ( a lot of it) to see if it temporarly goes away.
This is not a solutionn for the problem, but will help isolating it
Old Aug 14, 2008 | 01:43 PM
eZ's Avatar
eZ
This may not be your problem but my squeeking was coming from the lower frame rubbing on the front sway bar. had to do some grinding but fixed the problem. my car is very low though
Old Aug 14, 2008 | 05:29 PM
winfieldjuggalo
now that you mention it there is a small crack on my shock tower cap (the thing that the top of the shock bolts to). maybe its a combination of the worn UCA bushing and this crack but it never made this noise before i changed the spring seats.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
mungodrums
Sep 28, 2015 10:54 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
MasterLanMan
Sep 13, 2015 08:21 PM
