wireing, instument lights
Old May 10, 2005 | 08:31 PM
guitarist88's Avatar
guitarist88
Default wireing, instument lights
I have a 1967 289 the instrument lights do not work. So i replaced all the light bulbs and they still don't. I couldn't find any broken fuses. Can any one give me any tips? Where is the instrument panel fuse in case i wasn't looking at the right one but i think i was. And am i correct that the pull switch that turns the head lights on should also control instrument lights? does anyone know how i can fix them?
Old May 10, 2005 | 08:39 PM
6mustang6's Avatar
6mustang6
Default RE: wireing, instument lights
Yes, the light switch controls the dash lights. Turn the switch clockwise. It's a dimmer switch that controls those lights. So pull the switch out, then turn the ****. They should come on, if they dont and it's not a fuse, the switch may be bad.
Old May 10, 2005 | 08:43 PM
guitarist88
but the switch works to turn on the head lights. Is there anyway to check to see if the switch is bad before i buy a new one?
Old May 10, 2005 | 08:47 PM
6mustang6's Avatar
6mustang6
Did you try and turn the ****? I dont think you can check, just pull the **** out and wiggle it around while turning it. If you see the lights flickering on and off you know it's the switch.
Old May 10, 2005 | 08:48 PM
guitarist88
i tried that and i didn't see any flickering. could it be the wireing?
Old May 10, 2005 | 08:53 PM
6mustang6's Avatar
6mustang6
well, i dont want to tell yo the wrong answer but unless it's been butchered then it shouldn't be the wiring. Did you say all the fuses are good? Did you check the DOME fuse?
Old May 10, 2005 | 08:55 PM
guitarist88
whats the dome fuse?
Old May 10, 2005 | 08:58 PM
6mustang6's Avatar
6mustang6
It's a smaller fuse on the fuse panel. Let me go look at mine and see if it controls the lights.
Old May 10, 2005 | 08:59 PM
guitarist88
thanks a lot
Old May 10, 2005 | 09:07 PM
6mustang6's Avatar
6mustang6
im sorry, the dome light controls the under dash lights and such. The instrument panel fuse probably controls the lights. Have you checked all the fuses?
