wireing, instument lights
Old May 10, 2005 | 10:06 PM
angelsmith00's Avatar
angelsmith00
Default RE: wireing, instument lights
I had the same trouble actually. We couldn't figure out why my instrument panel lights weren't working. Everytime we'd replace the fuse it would go out again. It turned out someone who owned the car before me had tried to ground the radio to the instrument panel wire. We found that out after we bough a new switch and everything. Bah, good luck, also the panel lights don't show up at all until night time.
Old May 10, 2005 | 11:14 PM
Markstang1969's Avatar
Markstang1969
Mine don't work either. The headlights work, but the dash is dark. Maybe I'll go to Ford and see if it's still under warranty...
Old May 11, 2005 | 09:36 AM
Soaring's Avatar
Soaring
I ♥ Acer
Take the switch out to check to see if the wire going to the panel has come off. Also check to see if the panel is grounded. For a wiring diagram, google it. Just type in 1967 Mustang wiring diagram, and you will get some diagrams for you to see if your's is hooked up right.
Nurdyguy
Jan 20, 2025 04:38 PM
Ford_Dude
Sep 15, 2015 03:25 PM
jaiidutch
Sep 14, 2015 10:29 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
