C4 Upgrade ?
Old Aug 4, 2008 | 12:24 PM
krobillard's Avatar
krobillard
Default C4 Upgrade ?
Looking at getting a Transgo kit for my C4, is it worth it? Has anybody installed this, and how hard is it?
Thanks
Old Aug 4, 2008 | 12:32 PM
tyler72's Avatar
tyler72
Default RE: C4 Upgrade ?
Are you looking at getting the whole kit, or just the shift kit? Also, if you are getting the whole kit, are you getting the performanc version with Kevlar clutches and bands, or just the stock rebuild kit? How much is it? What kind of power are you going to be throwing at it? We need details man, we can't just answer "is it worth it?" if we dont have any idea what its going in, how, much it costs, and how you want to use it. We simply need all the info you can practically give us so that we can make a better call on the situation.
Old Aug 4, 2008 | 01:01 PM
krobillard's Avatar
krobillard
I was looking at the hole Performanckit.My stock C4 is currentlybehind afreshly rebuilt 302/4bl-600holleyu w/Edebk Performer RPMIntake/mild cam/headers
Old Aug 4, 2008 | 01:11 PM
tyler72's Avatar
tyler72
You will be fine with the stock clutches. I have a C4 behind a 347 that makes abouts 420 HP and 400lb/ft of torque, and it still has stock style clutches and bands, and does just fine. However, to help them survive, I did install a TCI valvebody and aTCI 2nd gear servo. They put more pressure on the clutches/bands to help keep them from slipping. If you want a shift kit, thats cool, but I wouldn't reccommend you install it yourself if you haven't got a lot of experience with valvebodies. You get one checkball in the wrong spot and it can cause the trans to not shift at all, shift into more than one gear at a time, or even burn up the transmission. As far as quality, the Transgo shift kits are pretty good. They shift hard as hell when they are behind a stock torque converter. Actually, they shift so hard that I don't like them. A firm shift is good, but they literally "snap" the transmission into gear. But no, with your engine, a stock rebuild kit will do just fine. No need to spend the money on the high dollar stuff you don't need.
Old Aug 4, 2008 | 01:32 PM
krobillard's Avatar
krobillard
Thanks, just driving the car I don't feel the shift from2nd to 3rd at all. I only feel1st which is very short after taking off. I was going to take it to a performance shop and let them give some idea's. Speaking of idea's my rear gears are 3.0 and I was to replace them 3.55. I might feel the 2nd to 3rd shift with better gears?
Old Aug 4, 2008 | 02:03 PM
tyler72's Avatar
tyler72
Um, maybe, but probably not. It sounds to me like it isn't going into 1st. You should be able to feel (or at least hear the engine rpms drop)it shift both times if it is actually doing so. Have you tried shifting it manually? Also, the vaccum modulator may be out of adjustment. You can adjust that with an allen wrench by simply taking the vaccum line off of it (it comes down from the intake and plugs onto the transmission by the tailhousing) and sticking the allen wrench in there. If I remember correctly, turning it right makes it shift sooner, and turning it left makes it shift later. You may want to just do like you said and take it to a tranny shop that builds racing transmissions for older cars. They could help you out better since they could take a hands on look at the car and actually drive it.
Old Aug 4, 2008 | 03:14 PM
muggsy's Avatar
muggsy
I have this Transgo kit (performance upgrade) plus a TCI 2500 RPM torque converter and perf planetary and Transgo shift kit in my car. I'm running a 400HP at the crank 347, 325ish to the wheels in my 67 vert. I love the firm shift, its not a head snapping shift, but a firm, quality shift when you get on the gas. Can't say enough about it, of course I haven't ever had anything different but the old stock C4. As they say, if you've been driving a Schwinn your whole life and never tried anything better, you might think you have the best. who knows?
Old Aug 4, 2008 | 09:16 PM
krobillard's Avatar
krobillard
Thanks Muggsy, I feel like I need the change, with that upgrade and gear I sure hope to feel some type of difference.
Were did you get your TCI2500 RPM Torgue converter?
Old Aug 4, 2008 | 09:34 PM
65Coupester's Avatar
65Coupester
I got a Transgo 'stage 2' shift kit off ebay. Put it in a stock C4.
A definite improvment. At least I can tell when it shifts, however it still shifts too early in IMO.
I did adjust the vacuum modulator. I thought the instructions were clear and it was painless.
PaulH2
20
Jan 31, 2016 09:48 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
UrS4
Sep 30, 2015 10:13 AM
