66 electric problems Directionals ???
Old Aug 4, 2008 | 09:45 PM
hobbydude's Avatar
hobbydude
Default 66 electric problems Directionals ???
Hi I have a 66 that when the left directional is on the right rear blinks, and when I turn the headlights on the right directionals work but not the left, I cleaned up the connections, and replaced the switch in the steering colum, and lights are bright so it doesn t seem to be bad grounds, any ideas ?
Old Aug 5, 2008 | 07:43 AM
67 evil eleanor's Avatar
67 evil eleanor
Default RE: 66 electric problems Directionals ???
May be in the column or a crossed wire. The easist first step is again to check the grounds. Only takes a minute.
Old Aug 5, 2008 | 02:56 PM
jlg2002's Avatar
jlg2002
To agree with 67. Bad grounds on the light sockets will drive you crazy. If you have the wiring in the correct spot,clean the grounds (not just check them)
GimpyHSHS
Sep 18, 2015 12:27 PM
TfcCDR
Sep 14, 2015 12:08 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
5.0 kevo
Sep 3, 2015 06:24 PM
