Installing a New *&%#@ Ignition Switch
Old Aug 6, 2008 | 09:28 AM
DCStang65's Avatar
DCStang65
Default Installing a New *&%#@ Ignition Switch
The ignition switch in my 65 Coupe fell apart (literally), and I am replacing it. Everything is hooking up fine switch-wise, but for the life of me I can't get the f-in lock cylinder to seat and click in place. Just will not engage. Know am supposed to align and then push and turn to lock it into place. But won't go.
Anyone have insight? Got the switch and cylinder from Autozone, and are to spec.
Old Aug 6, 2008 | 09:43 AM
tyler72's Avatar
tyler72
Default RE: Installing a New *&%#@ Ignition Switch
The crapzone! I have never had any luck with them getting me the right parts. They have always been junkordidn't fit correctly.Either the parts are not made correctly or you are doing it wrong.
Old Aug 6, 2008 | 10:43 AM
tommyleea's Avatar
tommyleea
They can be a bear to install. If you think you have the pins lined up with the slots, then it sounds like you just need that last gasp push to clear the slots and be able to turn it. Take a walk, and then try it again. Cheers..
Tommy
Old Aug 6, 2008 | 11:02 AM
73 Sportroof's Avatar
73 Sportroof
Is that the one on the dash? I think you have to put the cylinder in and push the button with a paperclip (the little hole next to the key). Rotate counter clockwise while holding the button in. It should push in then and be able to turn to acc and lock in.
Old Aug 6, 2008 | 01:28 PM
SJs 66coupe's Avatar
SJs 66coupe
On my '66 I had to use the paper clip to release the lock to get mine back in as well....thought it was just me but maybe not.
Old Aug 6, 2008 | 02:00 PM
DCStang65's Avatar
DCStang65
Parts are right. Triple checked that...
Way they are built, it is really hard to tell if the flange on the lock cylinder is actually seated in the ignition switch slot. Only one way to put that bugger in. Will try pushing in the pin and turning. Instructions say clockwise to get it back in. I'll try the other way.
In the meantime, anyone up to giving me a push? [:@]
Old Aug 6, 2008 | 02:36 PM
restomod66's Avatar
restomod66
Turn the cylinder clockwise to reinstall!! Counterclockwise to take out.
Old Aug 6, 2008 | 03:59 PM
73 Sportroof
Clockwise reinstalls after it is in the counter clockwise position to insert.
Push the button and turn the key counter clockwise, then insert cylinder in the switch and turn clockwise.
Old Aug 7, 2008 | 11:56 AM
DCStang65's Avatar
DCStang65
Thanks to everyone for the help. Got the sucker in there, after some real twists and turns. Great advice. Love this forum.
Old Aug 7, 2008 | 12:01 PM
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
http://www.mustangmonthly.com/howto/...hes/index.html
