351w reverse water pump part#
Old Aug 6, 2008 | 07:49 PM
92stangerang's Avatar
92stangerang
Default 351w reverse water pump part#
i guess i need a reverse water pump. thats what my step dad said. so far ive replaced the water pump, thermo, radiator and double checked the fan working. so anyone have a part number on a reverse water pump for a 351w??
Old Aug 7, 2008 | 12:17 AM
mhickl's Avatar
mhickl
Default RE: 351w reverse water pump part#
i got mine from jegs but it was for a 302. i don't know if they are the same.
555-51071
Old Aug 7, 2008 | 01:12 AM
David09sp's Avatar
David09sp
I know I feel like a walking advertisement, but hey there prices arent the best but you can get the numer...npdlink.com.
I know, I know.
Old Aug 7, 2008 | 06:44 AM
tyler72's Avatar
tyler72
Are you running a serpentine belt setup or V-Belts? You should be able to get a pump for a 90 model Mustang with a 302, and it should bolt on (302 & 351W pumps are the same)as long as the timing cover is for a reverse pump, and not a standard one. They are different between standard and reverse rotation pumps.
Old Aug 7, 2008 | 08:36 AM
92stangerang
whats the diff betweet serp. and v? its got the alt pulley , crank, and water pump in a circle.
Old Aug 7, 2008 | 08:37 AM
92stangerang
ok so that water pump wouldnt work cause everything runs clock wise.....right?
Old Aug 7, 2008 | 08:57 AM
jcthorne's Avatar
jcthorne
ON a serpetine setup the water pump runs in reverse due to the s shape route of the belt between the crank and water pump pully.
Old Aug 7, 2008 | 09:58 AM
tyler72's Avatar
tyler72
A serp. belt has like 6 ribs and is flat looking,aboutan 1 1/4" wide,like a belt you would put around your waste. A v belt only has only one rib, and it like 3/8" to 1/2" wide.
Old Aug 7, 2008 | 10:03 AM
92stangerang
yeah its a v belt. heres the one i think will work.??? but someone said something about changing the timing cover... do i have to do that too or can i just get this and slap it on?? http://store.summitracing.com/partde...p;autoview=sku
Old Aug 7, 2008 | 10:48 AM
tyler72's Avatar
tyler72
If it's v belt, you cannot run a reverse rotation pump. Period. It will cause the pump to turn backwards! I said that about the timing cover. There are 2 different styles, one for standard roation, one for reverse rotation. If the pump will physically bolt on, and all of the holes are lined up, you have the correct cover.
