spark plug clearance
Old Aug 14, 2008 | 02:09 PM
jimmy428's Avatar
jimmy428
Default spark plug clearance
i can't seem to fit a spark plug socket over my #4 plug on the driver's side (the one furthest back).
it has headers on it and i think they may be the culprit. i am forced to half-*** tighten it with pliers and it always comes loose after a while.
is there something i could buy to fit over this plug in such a tight spot or should i get physical with the situation and grind the header flange?
i have seen something in a book sometime that would work, but stupidly i forgot where i saw it and what it was called.
help please.
Old Aug 14, 2008 | 02:17 PM
1965fastback's Avatar
1965fastback
WHen i had the seals replaced in the motor on my truck (it has headers too) the mechanic said he had to unbolt the header to replace the spark plug, but a grinder to the flange might help some. Try using a swivel on your socket.
Old Aug 14, 2008 | 02:27 PM
JMD's Avatar
JMD
Maybe you could buy a sparkplug with a short insulator for the #4 hole?
I have seen this done.... see if you can get a socket on the plug if you break the old one off..... then you will know...
Old Aug 14, 2008 | 02:33 PM
JMD's Avatar
JMD
Damn... post and repost...
You might want to see if a plug with a short insulator may be available, and/or workable...
I have seen this solution used in a magazine article...
Old Aug 14, 2008 | 08:41 PM
.boB's Avatar
.boB
Use a mirror and a flashlight to look in there and see what the problem is. Since it's only one cylinder, it's probably a bit of the gasket hanging down. You can shave that off with a razor knife.
If it is the header flange, You'll have to pull it off and grind it down a little. Be sure to mark the area carefully before removing the header.
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
firehorse02
Nov 16, 2015 11:28 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
