Tire Troubles
Old Aug 14, 2008 | 02:28 PM
Stangs4Life's Avatar
Stangs4Life
Default Tire Troubles
I ordered 15x7 Magnum 500 (4.25 BS) wheels to replace the 14s with hubcaps quite a while ago. I just recently bought tires and they dont fit, so before I screw up a second time, will a 215/65/15 (recommended by a friend) fit all the way around without any issues? suspension is stock as far as i know, and it has all drum brakes. I am getting ready to order these so I want to make sure that they will fit first.
edit: whoops, its a 66
Last edited by Stangs4Life; Aug 14, 2008 at 02:29 PM. Reason: forgot to specify the year
Old Aug 14, 2008 | 02:34 PM
Nick.Simonds's Avatar
Nick.Simonds
http://www.dodgestang.com/Tire%20Fit...ide%2065-6.pdf
Old Aug 14, 2008 | 02:41 PM
Stangs4Life
Thanks..somehow, I missed that third 15x7 4.25 listing before
Old Aug 14, 2008 | 08:29 PM
JamesW's Avatar
JamesW
These are 215/60-15s on the same wheels.
I'd go a little shorter than 65's.
http://www.midnightdsigns.com/Mustan...ndar/CAL02.jpg
Old Aug 14, 2008 | 08:36 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
215/60/15 is what I run with 4" backspacing. I've done the Shelby Drop and occasionally the fronts rub at the top. It only happens when the wheels are turned and I'm going up a driveway type ramp or entrance. I think with 4.25" and no drop you will have no problems. Especially if you go with the 60 series. They're still pretty big diameter wise. I like the tall tire because that's what the stylists had in mind when they designed the car. O-rings are for ricers.
Old Aug 14, 2008 | 10:59 PM
Stangs4Life
Alright, thanks everyone for all of your input. I appreciate the help and I know that I came to the right place.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
