do I have an A or C code ?
Old Aug 18, 2008 | 06:29 PM
blue66mustang's Avatar
blue66mustang
Originally Posted by kalli
But as all the 66 289s are same compression ratio the only difference seems to be the intake and carb
Nope thats incorrect. For 1966...
An "C" code 289 2V has a 9.3:1 ratio
An "A" code 289 4V has a 10.0:1 ratio
An "K" code 289 4V has a 10.5:1 ratio
The difference is in the pistons.
The bore & stroke is all the same as are the cylinder heads for the "A" & "C" code motors.. The "K" code had upgraded heads with spring pockets and higher pressure valve springs and different camshaft. All three shared the same head chamber CC's, valves and connecting rods, with bigger rod bolts in the "K" code. The "K" code had a slightly bigger bore/venturi carb. There are a few more differences but they are minor.
Old Aug 18, 2008 | 07:07 PM
racin66coupe's Avatar
racin66coupe
i wish i had K code
Old Aug 18, 2008 | 07:31 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
The A code engine also had a different cam than the C code.
Old Aug 18, 2008 | 08:18 PM
Starfury's Avatar
Starfury
I believe cam was the same as well.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
