1/4 tank
Old Aug 23, 2008 | 04:16 PM
Rudy's Avatar
Rudy
Question 1/4 tank
I replaced my fuel gauge sending unit after the gauge read full by the ground test, and the voltage regulator on the back of the gauge pannel because my fuel gauge was not working. I now have a full tank of gas and the gauge reads 1/4 tank. Do I need to ajust the gauge or sending unit or could this be caused by something else. thx.
Old Aug 23, 2008 | 07:03 PM
az1966's Avatar
az1966
is it installed in the right position,,I changed mine and it only reads 3/4 when the tank is full
Old Aug 24, 2008 | 10:33 AM
Cogtx's Avatar
Cogtx
Changed my sending unit out a few years back on the 67 coupe. The sending unit had an adjustment screw to raise/lower the float arm. Justed guessed at the position and the gauge reads about right. If you have no adjustment screw, guess you could bend the float arm to correct for the difference in gauge reading...
4cylinderplus2
Oct 9, 2020 07:45 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
mrappe
Sep 26, 2015 10:16 AM
zachary1988
Sep 4, 2015 03:04 PM
