Air compressor
Old Aug 25, 2008 | 10:26 PM
64to66's Avatar
64to66
Default Air compressor
what specs do i need for a compressor to paint with? how big of a tank, psi etc....
Old Aug 25, 2008 | 10:28 PM
1slow67's Avatar
1slow67
ROTM Moderator
Most of the time it tells you on the bottle of paint. I know you will need a limiter on the gun or on the hose.
Old Aug 26, 2008 | 08:44 AM
mortman's Avatar
mortman
A 20 gal 2hp Cambels hosfeld will do, worked fine for me till i out grew it and needed more volume, you will need a water trap with a pressure regulator on it to reduce the out put for your needs
Old Aug 26, 2008 | 10:48 AM
64to66's Avatar
64to66
okay. are pressure regulators/water trap available as add ons? i ask because i'll be borrowing the compressor from a friend and I don't know if he has that set up.
Old Aug 26, 2008 | 05:10 PM
Joe67's Avatar
Joe67
Banned
yes they are add ons, be sure to get a good one, not a tiny one. also you should use a regulator at the spray gun and a disposable filter before that regulator
Old Aug 26, 2008 | 05:23 PM
Joe67's Avatar
Joe67
Banned
Depending on the humity of the area you could use a filter like this at the compressor before the air hose
http://www.harborfreight.com/cpi/cta...emnumber=45009
then a regulator at the gun like this
http://www.harborfreight.com/cpi/cta...emnumber=90590
and a filter at the gun like this
http://yhst-13811118617756.stores.ya.../mot-d122.html
wow that stuff was actually hard to find online
also drain the compressor of all water before spraying
Old Aug 26, 2008 | 05:59 PM
64to66's Avatar
64to66
this is all great! thanks!!!!
Old Aug 26, 2008 | 07:25 PM
Joe67's Avatar
Joe67
Banned
just curious... what brand of paint are you using?
Old Aug 26, 2008 | 09:54 PM
64to66's Avatar
64to66
i'm using ppg base and clear
Old Aug 26, 2008 | 09:55 PM
1slow67's Avatar
1slow67
ROTM Moderator
good stuff
daltron
Apr 28, 2016 08:10 PM
Dokilar
15
Oct 16, 2015 08:13 PM
fastbackford351
Oct 1, 2015 12:24 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
