package tray
Old Aug 26, 2008 | 01:38 PM
jimmy428's Avatar
jimmy428
Default package tray
i can't seem to push this package tray all the way back. it is brand new from virginia classic and i tried putting it in but it is like i said. i can't seem to get the seat on either because of this. any suggestions please.
Old Aug 26, 2008 | 01:46 PM
Nabster's Avatar
Nabster
It may need trimmed some, if you have the old one, use it as a template to see how close you are.
Old Aug 26, 2008 | 01:48 PM
jimmy428's Avatar
jimmy428
that's the problem, i have no original to go from. only a chunk of it because it had choppy carpet from the previous owner and a chunk of the original left in it.
Old Aug 26, 2008 | 01:56 PM
jimmy428's Avatar
jimmy428
just so we're clear it installs like this, right?: package tray, side panels, seat, done. on a 1968 coupe.
Old Aug 26, 2008 | 02:25 PM
tyler72's Avatar
tyler72
So... where are the pictures????
Old Aug 26, 2008 | 02:47 PM
boogerschnot's Avatar
boogerschnot
Does it need to be put under the lip of the window seal/trim? Thats how my plastic 69 had to go in..
Old Aug 26, 2008 | 02:54 PM
66 Restomod's Avatar
66 Restomod
Default Cutting required for mine
I used a putty knife to slide mine under the rear window gasket. But I then had to trim a half inch or so off the straight side with a jig saw and then cut a notch in each corner where the shelf butts up against the lower window corners. Not much of a "goes right in" thing, but they seldom are. I also covered mine in vinyl that matches my rear seats but that's not factory.
Old Aug 26, 2008 | 04:01 PM
SalikDDD's Avatar
SalikDDD
i got a steel one.. hell that thing didn't even fit. i made mine out of wood and coated it with carpeting and drilled my speakers directly to it. works great.
Old Aug 26, 2008 | 07:50 PM
jimmy428's Avatar
jimmy428
i had to slide it under the window seal. i figured that out by forcing it back. you guys were right on. everything is nice and looks good. i got the vinyl wrapped one because i couldn't find one factory with precut holes. anyway, thanks for the replies. i only had problems with the holes not matching up so well. i used some grills that i had from my 68 dart gts (put factory tray back in with integrated perforated speaker holes). i shouldv'e used sheet metal screws to mount the grill instead of through bolts because it was hard as i had to do notch the corners to get them in. if i do it again i will have the factory grills anyway.
Old Aug 27, 2008 | 12:53 AM
Nabster's Avatar
Nabster
Factory ones didn't have holes... that may be why
