wont stop running
Old Aug 26, 2008 | 09:26 PM
kgmunro's Avatar
kgmunro
Default wont stop running
Hey guys I have a question. I am putting an engine in a friends 73 351c mustang. It went in great and starts great but when I turn the key off it keeps running. what did I do wrong. I reconnected the harness that was already there and did not modify anything. any suggestions??
Old Aug 26, 2008 | 09:33 PM
1965fastback's Avatar
1965fastback
Welcome to the forums! It sounds like the starter relay is not grounding to the body. Make sure it is snugged up to the inner fender. Good luck!
Old Aug 26, 2008 | 09:52 PM
1slow67's Avatar
1slow67
ROTM Moderator
My friend had this problem with his 68. His ignition switch was messed up. How old is the ignition switch?
Old Aug 27, 2008 | 09:05 AM
kgmunro's Avatar
kgmunro
not sure how old the ignition switch is but the starter relay was put on when I put the engine in. Does the starter cable mount to one side (large terminal) and the battery posative to the other large terminal? I have never done a ford swap in one of these cars before.
Old Aug 27, 2008 | 09:35 AM
85lebaront2's Avatar
85lebaront2
You are correct on that. One item to check, there are two small terminals on the starter relay, s and i, if the car starts normally, that is doesn't try to crank as soon as the key is turned on, they are wired correctly. Try disconnecting the i terminal after turning the key off, it is the ballast resistor bypass, if the engine stops, replace the relay. It was not an uncommon failure of these.
Old Aug 27, 2008 | 09:52 AM
67coupe's Avatar
67coupe
I had this problem on my F100. If I pulled the "I" wire from the solenoid it quit. I replaced the solenoid with no effect. Found out there was a bad diode in the Alternator back feeding the ignition circuit.
Old Aug 29, 2008 | 08:18 AM
kgmunro's Avatar
kgmunro
Default asking??
Sort of a stupid question, but I started the car without throwing the alternator belt on...(did not get one yet), just to see if it starts. Could this be the problem? I will try to get a belt today and will then try putting the old starter relay back on. Talk to you guys soon.
Old Aug 29, 2008 | 03:38 PM
kgmunro's Avatar
kgmunro
Default problem solved!!
you were right guys, when I put the old starter relay back on the car shut off fine. Must be a faulty relay. Thanks for the help! Adding a belt did not hurt either!
Old Aug 29, 2008 | 03:48 PM
jlg2002's Avatar
jlg2002
Glad you found it, welcome to the forum. FYI the belt doesn't matter- it just spins the alernator so it charges the battery.
mtgldr
Feb 3, 2024 09:00 PM
musnicki
Sep 23, 2015 07:11 AM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
