power brakes.
Old Aug 27, 2008 | 01:49 PM
harrisont's Avatar
harrisont
Default power brakes.
is this what im looking for to get it done?
http://www.car-stuff.com/carparts/fo...049817350.html
Old Aug 27, 2008 | 01:55 PM
ccs47's Avatar
ccs47
Try this:http://www.discbrakeswap.com/Mustang...s%20SWAP1.html
(The 65.PBU power brake upgrade kit has all new parts including booster, bracketry, power master cylinder upgrade, hose, power brake pedal push rod, and hardware. The kit can only be applied to 64-66 automatic transmission equipped cars. This kit is shipped with no additional S&H charge when purchased with a SWAP kit.)
Works on V-8 equipped cars, if yours is an I6, then you would need to upgrade your spindles.
PS- I'm not advertising, I just bought this sytem for my wife's 65. There are other choices, this happens to be the one I chose.
Old Aug 27, 2008 | 02:05 PM
harrisont's Avatar
harrisont
yeah i was thinking about that, saw it on ebay. was it easy to install?
Old Aug 27, 2008 | 02:28 PM
ccs47's Avatar
ccs47
Just got it yesterday and only opened one box.
It should be an easy install, EXCEPT that there will be some new plumbing required. You're going from a single system to a dual system with a propotioning valve, so I will have to buy some brake line and bend it into place. Also, if I were you, I would buy the OE type proportioning valve and not mess with the "adjustable" valve that comes with it, the seller will sub the OE version for some extra $$. (that's what I did).
I'll try to take some pics as I go along with the install this weekend.
Old Aug 28, 2008 | 09:07 PM
harrisont's Avatar
harrisont
i got this
http://cgi.ebay.com/ebaymotors/ws/eB...m=370078871334
now all i have to do is find a power steering pump but i dont know which one to get that would fit. its the power steering unit that uses the power ram.
Old Aug 28, 2008 | 10:51 PM
andrewmp6's Avatar
andrewmp6
npd should have all the power steering parts if not http://www.abspowerbrake.com/
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
