69 pulls to the left
Old Aug 30, 2008 | 02:22 PM
dvanv's Avatar
dvanv
Default 69 pulls to the left
My 1969 stang pulls to the left when going down the road. I have bled the brakes twice and it seems better right after but the next time I drive it the same pull occurs.
Anyone have some ideas????????
Old Aug 30, 2008 | 02:34 PM
Timetravelinn's Avatar
Timetravelinn
I would take it to a alignment shop and have it realigned....did you do a brake swap or anything?
Old Aug 30, 2008 | 03:15 PM
Carlos Pineiro's Avatar
Carlos Pineiro
Did you check the tire pressure? If the air difference in my '69's front tires vary by 5 psi, it will pull towards the side with less air. Also, the steering wheel won't point straight when you're driving (bottom spoke at 6 o'clock) unless the air is equal. If you have a 2 spoke factory steering wheel, it should be horizontal.
It could also be your coils if they are old enough. Start with equal air, then check the alignment.
The only other thing that would make you pull to the left is if you personally can't lay off the chimichangas before dinner and you're tipping the scales at 400 lbs+. Try rice cakes if that is the case.
Carlos
Old Aug 30, 2008 | 08:36 PM
dvanv's Avatar
dvanv
Default Not alignment or air pressure
You can hear the brake squeal when it locks up the wheel.
Old Aug 30, 2008 | 08:39 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
If you have disc brakes the caliper could be sticking. Jake it up and see if it releases.
Old Aug 31, 2008 | 09:31 PM
dvanv's Avatar
dvanv
No disc brakes.......I have brake shoes.......anymore ideas to help me.
Old Aug 31, 2008 | 09:54 PM
shr's Avatar
shr
caster could be off, take it to the mech. shop
Old Aug 31, 2008 | 09:56 PM
1slow67's Avatar
1slow67
ROTM Moderator
Yeah, it sounds like alignment is off.
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
jrrhd73must
Oct 2, 2015 09:17 PM
Drastang
Sep 29, 2015 03:31 PM
