Cowl Info?
Old Sep 3, 2008 | 02:35 PM
my66prjct's Avatar
my66prjct
Default Cowl Info?
Allright, I have read many posts on this but still muddy on some of the information. As I took the front fenders off the mustang, I found that there was some repairs done to the side cowl panels. I removed them to put in new sheet metal. As those came off I saw that they had also done repairs on the bottom cowl. One side of the cowl had a 4" PVC pipe for the vent and the other, a piece of some rodent control mechanism,(the sticker was still on there). I have some questions to removing the entire cowl.
1. Is the cowl structural, if so how do I prepare for removal? Do I have to brace it, if so where and with what? Keep in mind that the outer cowl sheet metal has been removed.
2. As far as the spot weld removal, I have seen that the drill bit is better. What size should I get, and how do I properly use it without tearing up too much?
I do want to keep the top part if possible, as I take the top part off I will see if I can just patch the bottom half corners with repair sheet metal panels?
Thanks.
Old Sep 3, 2008 | 11:22 PM
mustanglover66's Avatar
mustanglover66
1. the cowl is structural, remove the motor and trans. if they are not already out and support the frame rails.
2. I used a drill type spot weld cutter on mine word good 5/16 are the size of the spotwelds but I'm putting mine back together with 3/8 plug welds because 5/16 is a little small to plug weld. You can also use a pilot point drill bit but they tend to cut into the lower panel.
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
RCS02v6
Sep 29, 2015 01:46 PM
junior04
Sep 28, 2015 10:53 AM
GLOCKer
Sep 28, 2015 07:36 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
