Body Filler
Old Sep 5, 2008 | 09:58 PM
mortman's Avatar
mortman
Default Body Filler
I just finished epoxy priming my ride, next step is body filler to fix the imperfections. I have the filler "evercoat rage gold" must I sand the primer first or just run with the filler? I have 12 books on body work and all say something different? whats the next step?
Old Sep 5, 2008 | 10:41 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
depends on the tech sheet for your epoxy primer usually they have a time window. like 12 hours you need to make sure
Old Sep 5, 2008 | 10:49 PM
65rangoon's Avatar
65rangoon
as far as sanding before or after, id personally do it before.
You dont need to coat the entire car with abunch of filler to completely smooth it out, if you do that youll end up sanding most of it off anyway and only leaving small sections.
I would block sand the primer quick with a long board and blow it off/wipe it down with a tack cloth. Do it lightly though as it will show the high & low spots where you need to work on.
When i say lightly i mean just do a couple X motions with little pressure on the board, just enough to knock down the top coat of primer.
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
