tunes and tuneups
Old Sep 19, 2008 | 09:48 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
how low is it at idle you need at min 10-15lbs of pressure
Old Sep 19, 2008 | 09:51 PM
javier146's Avatar
javier146
It was low, how do you raise the oil pressure?
Old Sep 19, 2008 | 09:57 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
new oil pump, and if that doesnt do it new bearings
Old Sep 19, 2008 | 09:59 PM
racin66coupe's Avatar
racin66coupe
how does it sound when you fire it up? you should have atleast like 30 at idle IMO depending on engine of course. but for a v8, anything lower would scare me
Old Sep 19, 2008 | 10:19 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the min rule of thumb is 10 psi per 1000 rpm, race motor with tighter tolerance usually run 5psi per 1000rpm
Old Sep 19, 2008 | 10:21 PM
javier146's Avatar
javier146
supposedly it is a 6500 rpm motor, and had a high volume pump.
Old Sep 20, 2008 | 09:15 AM
racin66coupe
hows it sound on startup
Old Sep 20, 2008 | 10:35 AM
MonsterBilly's Avatar
MonsterBilly
when they rebuilt the engine did they do any head work?
Did you replace it with an agressive cam?
If you did put an aggressive cam in it and did not work the heades than the valve train is the issue. If you over revved it with stock heads it will cause valve problems. Did you install new valve springs and retainers?
Old Sep 20, 2008 | 11:17 AM
javier146's Avatar
javier146
well now the engine constantly makes a sound that is coming from under the cylinder heads, but before it sounded like the idle was set too low.
Old Sep 20, 2008 | 11:19 AM
javier146's Avatar
javier146
heads are rpm heads with crane cams push rods, 1.6 roller rockers, and I would think edelbrock's heads have good springs.
