Tail, and Brake Lights?
Old Sep 20, 2008 | 09:02 PM
southark66's Avatar
southark66
Default Tail, and Brake Lights?
I just bought this 66 and at first the brake lights worked(just very dim).And the signal lights worked on one side but not the other. so i replaced a bulb , but know the brake lights dont work at all and both signal lights dont ether. The front signals will just stay solid. Where do i need to start?
Old Sep 21, 2008 | 01:43 AM
MonsterBilly's Avatar
MonsterBilly
It sounds like you need a flasher relay. Or you may need to re ground them both. check the ground wires. they are the wires that attach to the body near the light housings.
Old Sep 21, 2008 | 03:10 AM
Stepman's Avatar
Stepman
First of all, make sure your charging system is working.
Old Sep 21, 2008 | 07:42 PM
southark66's Avatar
southark66
whats the best way to check the charging sys?
Daddys Girls GTs
Sep 14, 2015 08:46 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
amandahchase
Sep 3, 2015 10:09 AM
