Where is the speedo cable?
Old Sep 21, 2008 | 08:34 AM
chewy1234's Avatar
chewy1234
Cool Where is the speedo cable?
I need to take my 65 guage cluster out and apparently need to disconnect the speedo cable first what is the secret to doing that?
Old Sep 21, 2008 | 10:43 AM
1965fastback's Avatar
1965fastback
Reach up under the dash and you will be able to find the cable where it goes into the cluster. All you need to do then is un-screw it from the cluster.
Old Sep 21, 2008 | 12:00 PM
HGC's Avatar
HGC
Yeah, but it can be hard to do. There is not much room up there and I have always had difficulty getting my fat hand up in there and still being able to turn the cable to remove or reattach it. Getting it off is easier than getting it back on though. If you have a wife/girlfriend with small hands, or kids, you may have to ask them for help.
Old Sep 21, 2008 | 12:03 PM
chewy1234's Avatar
chewy1234
But that needs to be undone first on a 65 right. I shouldn't pull it out some and try reaching behind?
Old Sep 21, 2008 | 04:24 PM
HGC's Avatar
HGC
There is a fair amount of slack in the speedometer cable. Might be enough to do it that way.
Old Sep 21, 2008 | 05:50 PM
wumarshall82's Avatar
wumarshall82
I know on my 66 I took the screws out for the cluster and pulled it out and then I unscrewed the speedometer cable.
Old Sep 21, 2008 | 06:32 PM
zggill04's Avatar
zggill04
I had room to unscrew the cluster and pull it out and unscrew the speedo cable
Old Sep 21, 2008 | 08:13 PM
1965fastback
In my car i have to unscrew the cable first because there is little slack in the cable.
Old Sep 22, 2008 | 12:55 AM
photocliff's Avatar
photocliff
The speedo cable slack may be from a loose fitting cable coming through the firewall. This may allow unwanted air or fumes to enter from the engine area into the cabin area
Old Sep 22, 2008 | 08:36 AM
wumarshall82
Mmm...maybe i'll have to check that out...
