What to clean engine and engine compartment with?
Old Sep 24, 2008 | 07:26 PM
unit91's Avatar
unit91
Question What to clean engine and engine compartment with?
Spray GUNK degreaser? Carb cleaner? Brake cleaner? Plain water with a high pressure sprayer? Bud Light? What???
Old Sep 24, 2008 | 09:10 PM
65rangoon's Avatar
65rangoon
i vote MGD, miller chill, or any other horrendous beer out there.
i would try some simple green or regular engine degreaser. the brake cleaner may do hard to the paint.
Not sure how high of pressure youd really want to use. id probably only use a regular garden hose nozzle if any real pressure at all
Old Sep 24, 2008 | 09:12 PM
flyingfool's Avatar
flyingfool
i use an electric power washer. (partly cuz i dont have a gas one and second, preasure is a little intense on those things.) and a few bottles of simple green. do it about twice a year, but my engine bay is kinda grungy anyway, so im not real picky right now
if you try any of the **** in the can beers, let us know how it goes! you could have the next miracle cleaner!
Old Sep 24, 2008 | 09:14 PM
unit91's Avatar
unit91
If I remember back far enough I think I covered the distributor and carb with a plastic bag. Did I miss anything?
Old Sep 24, 2008 | 10:35 PM
Carlos Pineiro's Avatar
Carlos Pineiro
The solenoid and the coil.
CP
Old Sep 25, 2008 | 12:22 AM
photocliff's Avatar
photocliff
Don't forget to cover the alternator. Water will ruin the bearings in it.
Old Sep 25, 2008 | 12:35 AM
HGC's Avatar
HGC
And don't be suprised if won't start for a day or so. Even covering stuff, water seems to find a way to get something wet that it shouldn't. If it won't start up afterward, wait a day and try it again.
Old Sep 25, 2008 | 02:14 AM
flyingfool's Avatar
flyingfool
never had that problem
Old Sep 25, 2008 | 09:23 AM
65rangoon's Avatar
65rangoon
as far as the al goes, i just wouldnt soak it. i mean have you ever driven a car out in the rain and then popped the hood? EVERYTHING is wet.
Old Sep 25, 2008 | 11:20 AM
Jaded's Avatar
Jaded
I usually clean the carb with carb cleaner, then bag it up and use Simple Green on the rest of the engine. When I spray off the engine, I try not to concentrate the water on the Alt, Valve cover breathers, Wiring Blocks, or the Distributor.
An old trick for bringing back discolored hoses or paint (NOT ALUMINUM) is spraying with clearcoat.
