66 Mustang
Old Oct 7, 2008 | 06:56 PM
spellmac's Avatar
spellmac
Default 66 Mustang
My 66 289 3 speed Mustang makes a terrible vibration when I release the clutch in first gear. The whole car shakes. Second and third gear are fine. Any ideas?
Thanks
Old Oct 7, 2008 | 07:56 PM
Starfury's Avatar
Starfury
I'm assuming this is during normal take off and not a drag launch that might cause wheel hop
First thing I'd check would be motor and tranny mounts. Broken mounts are sure to cause vibrations exactly like that.
Assuming the mounts are ok, start looking at the clutch linkage. Bent linkage or worn (or missing) bushings will cause similar problems. It's very, very common for the bushings and felt grease retainers for the clutch z-bar to be missing entirely. Take the z-bar in your hand and see if you can slide it left to right. If you can, you need to replace the bushings and felts.
If neither of these things fix the problem, it's likely clutch chatter, which will require replaecment of the clutch.
Old Oct 7, 2008 | 07:58 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yeah +1 and possibly the bar itself
Old Oct 7, 2008 | 10:05 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
The shifter should move way to the right when you start off if you have a broken mount.
Besides those mentioned another possibility is a worn pilot bearing.
Old Oct 8, 2008 | 02:43 AM
390bigblock1's Avatar
390bigblock1
im having hte same problem but its only when i leave from dead stop and, for some reason my back tires keep making a odd sound. but really id also check your U joints.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
chain
Aug 17, 2015 08:52 AM
daytooday
Aug 11, 2015 09:22 AM
