Flex plate/ Starter gear
Old Oct 9, 2008 | 08:46 PM
jcar22's Avatar
jcar22
Default Flex plate/ Starter gear
I put an AOD tranny in my 66. The only problem i have is the original starter came from a smaller (less teeth). I have the starter that goes with the AOD. but it is a 2 wire starter. The OE starter was single wire. how do you get the 2 wire starter to work? Thanks
Old Oct 9, 2008 | 09:55 PM
zggill04's Avatar
zggill04
Is it a + and a -? All you would have to do is run a negative wire and ground it out.
Old Oct 11, 2008 | 08:36 PM
jcar22's Avatar
jcar22
No its not +/- . it has to do with solinoid. The solinoid on the two wire starter is on the starter.how do you by-pass fender solinoid, and go to the one on the starter?
Old Oct 13, 2008 | 03:15 PM
jcar22's Avatar
jcar22
Well i got my answer while going through my latest edition of Must. Mo.
move pos. cabletofrt. of solinoid on fender,then run new 12 ga. wire from back of sol. on fender to sol on starter.
Bokeo
Oct 10, 2015 08:28 PM
UrS4
Oct 3, 2015 06:23 AM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
logan409
Sep 26, 2015 07:43 PM
