help buying a welder
Old Oct 13, 2008 | 08:53 AM
68 Coupe's Avatar
68 Coupe
Buy the Millermatic 140 and be done with it. It takes 115 volt input power, will run solid wires that require a shielding gas for thinner materials, and comes with a regulator for your own bottle. you can also run flux cored self shielded wire with DCEN current to weld thicker parts such as frames etc. See, one stop shopping for all your welding needs
Old Oct 13, 2008 | 12:04 PM
fakesnakes's Avatar
fakesnakes
I need to replace my MIG welder. It still works, but is 20 years old and starting to fall apart. WHere is the best place to buy the Millermatic 140?
Old Oct 13, 2008 | 12:31 PM
68 Coupe's Avatar
68 Coupe
Fakesnakes,
Go to your local welding supply house that stocks Miller equipment and they should able to take care of you. If that doesn't work, go to http://www.millerwelds.com/wheretobuy/ and you can locate a local dealer by entering your zip code.
Good luck
Old Oct 13, 2008 | 03:14 PM
fakesnakes's Avatar
fakesnakes
Thanks, man, they sell them at the ABCO right down the street.
Old Oct 13, 2008 | 05:00 PM
390bigblock1's Avatar
390bigblock1
anyone know where to get a good deal on an arc welder? lots of differnt type of welding rods and you can just pretty thick steel with the air arc rods.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
ChampInSD
Oct 2, 2015 04:55 AM
winner99
Oct 1, 2015 10:52 AM
Sep 25, 2015 06:30 PM
