Scary Steering problem
I agree with most of these guys (except Groho. No offense, but caster is usually what causes pull
. With the erratic pull conditions you're experiencing, it sounds like something's worn. A worn idler arm bushing is very common and will cause these symptoms. Strut rods are almost as common and can cause a pull as well, but usually the change will come when braking or when going over bumps.
A good alignment shop will check EVERYTHING before aligning the car. It makes no sense to align a vehicle if there are loose parts.
. With the erratic pull conditions you're experiencing, it sounds like something's worn. A worn idler arm bushing is very common and will cause these symptoms. Strut rods are almost as common and can cause a pull as well, but usually the change will come when braking or when going over bumps.A good alignment shop will check EVERYTHING before aligning the car. It makes no sense to align a vehicle if there are loose parts.
uberstang1
Sep 20, 2015 06:42 PM
Sep 8, 2015 11:50 AM
