How much did you spend on paint?
Old Oct 16, 2008 | 10:28 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Originally Posted by 68EFIvert
You guys got off cheap. I was charged a little over $2k for paint and primer. I did use House of Kolor and they tend to be a bit more expensive but the effects are worth it IMO.
i painted mine HOK kandy for 150$ :P granted i got all the BC for free and used intensifiers in the clear instead of regular kandy
Old Oct 16, 2008 | 10:32 PM
67 evil eleanor's Avatar
67 evil eleanor
I know some paints cover better than others and their should be a rating on the coverage. On my 66 it took almost two gallons of base to get good coverage. It was Western Automotive and it was crap. Almost like spraying colored water. Following the base, I used a gallon of clear and this was a Vert! I did paint under the hood and deck lid and that will add up to several more square feet. It did in the end come out very good, still I think a gallon should have been enough if it was good quality. I learned to stay with the name brands. The local auto parts store recommended this crap and I haven't bought anything else from those bozos since. On the "E", I used less than a gallon of base and had some left over. I did put 4 coats of clear and had to bum some of a friend (less than a quart).
Old Oct 16, 2008 | 10:52 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
well there is a "rating" depending on the color you choose you select the correct sealer so you dont have that problem. for example you want to paint a dark dark blue over a factory white paint job you use a dark sealer etc
Old Oct 17, 2008 | 12:28 AM
68EFIvert's Avatar
68EFIvert
rmodel that looks great. Now only if you could fix that damn hole in your pants! LOL!! My paint job use 4 gallons of material. I suppose that is why the cost was as high as it was and I had to buy all of it. No free ride here, dang it!
Old Oct 17, 2008 | 12:29 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the hole is the reason they are work pants that was the first "kandy" i had ever painted pretty much an experiment :P
Old Oct 17, 2008 | 12:37 AM
Iskwezm's Avatar
Iskwezm
I spent about $1400 on the HOK orange,and another $6-700 on primer,silver base and white and pearl for the flames
Old Oct 17, 2008 | 01:05 AM
cprstreetmachines's Avatar
cprstreetmachines
Yeah, expect to spend a bit. the paint place next door says they use about1200-2500 in spray material. And 45 a gal for filler.
Old Oct 17, 2008 | 11:07 AM
boogerschnot's Avatar
boogerschnot
I called one place and they said that the color I am going with (sinful cinnamon Dupont) is $68 per quart..
Old Oct 17, 2008 | 11:34 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yeah reds are expensive then you gotta add in your reducer iirc dupont is 1:1
Old Oct 17, 2008 | 03:07 PM
67 evil eleanor
I don't guess theirs any reason to worry, if you gotta have it, you gotta have it. Today I spent about 200 bux on acid etch primer and 2K. Now the fun begins. I have always liked enamels, but the base/clears are much easier to correct mistakes. "Rmodel65", your paint looks great. I have ran into coverage issues before. It seems some colors cover better than others. Reds are the most expensive and also the most popular. I'm sick of Red (that is in my garage, I have 3 Red cars) but Rmodel65 and EFI, the Reds (or Candyapples) you guys have on your cars is outstanding. Today I was able to get the car in etching primer. My friend said that we need to throw in some "Silver Sparkles" and clear it over, and someone would like it! I'm not sure.
