brake help needed asap
Old Oct 18, 2008 | 04:51 PM
pnandy's Avatar
pnandy
Default brake help needed asap
ok ive pretty much finished converting my 68 fb from manual drums to power front disc only problem im having is on the orginal maunal brake pedal and were the brake light switch mounts to is higher on the pedal assembly and now with the power brake pedal it attaches to the pedal alot lower then were it does on the manual pedal and i have no idea how to mount it up to get it to work do i need another bracket for it to connect in that spot or do i need a diffent switch or .....
Thanks for the help in advance
-patrick
Old Oct 18, 2008 | 09:47 PM
pnandy's Avatar
pnandy
do you have a picture or a diagram of how the switch should be mounted to the brake pedal i wasn't one who took it apart and that guy can't remember how it goes back together so im stuck figuring this out? i can see the wiring reaching but not how the switch will mount up not fall off or get triggered when i push the pedal thanks
Old Oct 19, 2008 | 11:16 AM
pnandy's Avatar
pnandy
ok so i need a new switch i was trying to use the old one im using the bendix booster provided in the kit pretty sure pedal is mounted right
JonnyBlazeGT
Nov 3, 2015 01:10 AM
bond007
Aug 26, 2015 11:36 PM
fireboss343
Aug 21, 2015 06:25 AM
Fast-Hands
Aug 19, 2015 06:54 AM
defarmer
Aug 13, 2015 06:40 AM
