pcv valve
Old Oct 20, 2008 | 08:24 PM
robert912004's Avatar
robert912004
Default pcv valve
I have a 65 coupe with a 302. I fired it up over the weekend and noticed that the pcv valve has two hoses going to it. One hose is a large hose and the other one is small... the small one wasnt pluged up nor was it going to anything and it was creating a vaccum leak. Where is the small hose suposed to go? I have the bigger hose going to my carb... I plugged the small hose and it slowed my idle down... Is it suposed to be plugged off???
Old Oct 20, 2008 | 11:50 PM
65Coupester's Avatar
65Coupester
Well its late and I had some whiskey so i shouldn't respond here, but someone will set me straight.
Clearly your motor is probably 70's or later.
The small vacuum line was some sort of emissions deal the went to a water temp controlled valve and then to the carb. It defiantly should be blocked for now. Your motor will run better and get better mileage without that vacuum leak.
The big hose should go to manifold vacuum, most likely the carb spacer.
Easiest thing to do is get a PCV valve for a 65 and forget about the small hose. The one you have is probably fine anyway.
Yes, you do want the PCV valve, you don't need to worry about emissions on a 65 in most states.
Going to sleep.
Old Oct 21, 2008 | 12:49 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
leave it blocked off or buy a new pcv valve with just one nipple on it
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
