Rack&Pinion question..
Old Oct 25, 2008 | 08:11 PM
BCMC03's Avatar
BCMC03
Default Rack&Pinion question..
I'm new to the your forum, and have a couple of questions. Which rack/pinion system is the best and easiest to install? and is removing the stock shock towers difficult on a 65 V8 coupe? Thanks
Old Oct 25, 2008 | 08:13 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
plannin on doing a big mod motor or something? if not theres no need to remove the shock towers
Old Oct 26, 2008 | 05:56 AM
andrewmp6's Avatar
andrewmp6
Yeah what are going to do with the car?If you remove the shock towers you'll have to weld in a mustang 2 kit its a big job.
Old Oct 26, 2008 | 11:18 AM
cprstreetmachines's Avatar
cprstreetmachines
Unisteer BY FAR is the easiest install out there.
Old Oct 26, 2008 | 01:50 PM
jim moore's Avatar
jim moore
Default Rack and Pinion
I installed Randall's Rack and Pinion which was straight forward without removing shock towers, however I had to design a new support for the clutch Z-bar because steering linkage is in the way. If you have an automatic there is no issue.
Jim
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
KingRando
Oct 2, 2015 08:06 AM
DJ Piner
Sep 30, 2015 03:03 PM
Urambo Tauro
Sep 7, 2015 12:47 PM
