Still having wiring problems!!!!
Old Oct 27, 2008 | 08:43 PM
southark66's Avatar
southark66
Default Still having wiring problems!!!!
OK, ABOUT 2 WEEKS AGO EVERYTHING WAS WORKING FINE AND THEN, NOTHING WORKED RIGHT.BOTH TAIL LIGHTS STAY ON(OR BRAKE LIGHTS)NEITHER SIGNAL WORKS. I PULLED INSTRUMENT CLUSTER, BUT DIDNT SEE ANYTHING WRONG. BUT WITH MY METER I SEE A SHORT ON BOTH SIDES OF THE BRAKE LIGHT WIRES,WHICH WOULD EXPLAIN THE TAIL LIGHTS STAYING ON. WHERE DO I NEED TO START?
Old Oct 28, 2008 | 05:13 AM
kalli's Avatar
kalli
1. stop SHOUTING ;-)
2. explain: METER I SEE A SHORT ON BOTH SIDES OF ... (how do you mean short)
3. check if it's the brakelights or not. means have someone check if it's getting brighter when you step on the brakes.
4. disconnect the brakelight switch and see if the problem disappears. (all back to normal but brakes are not working). If that's the case adjust/replace your brake light switch
Old Oct 29, 2008 | 08:23 AM
southark66's Avatar
southark66
Sorry ive been away from my pc. The meter im talking about is a volt meter, i can check volts or check for short. (wires on the frame or other wires) I was told the middle pin on the brake light was only for AC. But i also have a full ground also.But when you hook a battery up the lights come on and stay, i pushed on the brakes but they didint get any brighter and even unhooked the brake light swtich, but still the same thing thanks
2007StangV6
Jan 28, 2016 06:09 PM
Doogie65
Sep 6, 2015 02:55 PM
zanemoseley
Sep 6, 2015 12:58 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
