Rearend problem?
Old Nov 2, 2008 | 12:14 PM
65MustangQT's Avatar
65MustangQT
Default Rearend problem?
well tried to take the Mustang for a little drive to make sure its not over heating anymore. didnt get a couple feet down the street and it sounds like a squeeling thats coming from the rear end. Gets high pitched with speed and only happens while in motion? I was told maybe the wheel bearing for the u-joint? Any other options? Thanks
Old Nov 2, 2008 | 12:23 PM
Gary H's Avatar
Gary H
Wheel bearings are not the same as u-joints. Does it make a loud clunk when you put it in gear?
Old Nov 2, 2008 | 12:56 PM
65MustangQT
yeah but only when you put in in drive..it just kinda jumps forward..and then it is fine..but I put it up on jacks and spun the back wheels and it is coming from the passenger side and from where i can tell the noise is coming from the brakes so..brakes are rubbing?
Old Nov 2, 2008 | 01:52 PM
Gary H's Avatar
Gary H
Or wheel bearing. There is a bearing on the axle that rides in the housing.
You can pull the wheel and look at the brake pads to see if they're worn out and dragging.
Old Nov 5, 2008 | 12:51 AM
65MustangQT
sorry, typo on the 1st one. I meant either or. Brakes are rubbing a little bit. Talked to a couple people with more experience with the older cars and I may need to grease or replace the u joint. Probly going to start there since wheel bearings are a bitch usually. Thanks
Seanam
Oct 4, 2015 10:15 AM
67LimeCoupe
Sep 30, 2015 04:46 PM
67LimeCoupe
Sep 21, 2015 06:34 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
