Engine block number
Old May 26, 2005 | 06:22 PM
hd429cj's Avatar
hd429cj
Default Engine block number
Does anyone know where to find the engine block number, its a 1971 Mach1 429CJ, I want to verify that it is the original block.
Old May 26, 2005 | 06:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Engine block number
Hey, welcome to the classic section on the MF. So, you have a CJ huh? Hellava nice engine. I don't know where your block code is on your car, but it is behind the starter on my old 65 289. There will be some early 70's model knowledgable folks who will chime in with correct information for you in a bit. So, just keep your pants on and order another round.
Old May 26, 2005 | 07:11 PM
Jinxed67Stang's Avatar
Jinxed67Stang
So thats where the number is on my 289 prolly... I've been lookin for that baby.. will it match the VIN if it's the original motor? Or do you how do you tell?
Old May 26, 2005 | 07:35 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, just take your starter out, and it will be stamped on the block. Haven't we been through this discussion before?
Old May 26, 2005 | 09:58 PM
Markstang1969's Avatar
Markstang1969
She be looky like dis:
That gasket is on the passenger rear of the engine (oil pan) so just above that. (My engine is upside down right now)
Old May 27, 2005 | 02:33 AM
eblues's Avatar
eblues
On a 428cj block, or any FE block I believe, there's a casting date on the front driver's side directly below the oil filter adapter. This only tells when the block was made, so if's within a few months or so earlier than the car's build date that's about as close as one can get to matching #s. If you're very lucky the vin number may be stamped in the back of the block which can only be seen with the transmission removed. I realize the 429 is a totally different block, but it might be worth a peek.
Granatelli Sales
Jan 20, 2020 12:34 AM
mdj89
Sep 6, 2015 11:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Sep 1, 2015 08:16 PM
kawiguy827
Sep 1, 2015 07:09 PM
