springs and shocks
Old Nov 5, 2008 | 06:44 PM
waldo786's Avatar
waldo786
Default springs and shocks
So, I've decided to go with KYB gas adjust shocks on my mustang, but am on a budget so if I don't have to I don't want to replace my springs, but should this be done when my shocks are replaced?
Old Nov 5, 2008 | 06:55 PM
1971mach1's Avatar
1971mach1
These aren't like struts, no need to replace springs unless they're broken
or the car is sagging.
Old Nov 5, 2008 | 09:26 PM
65Coupester's Avatar
65Coupester
Or you want a stiffer ride by going to a spring with a higher rate.
Old Nov 5, 2008 | 09:32 PM
Starfury's Avatar
Starfury
Also, you don't have to remove the springs to remove the shocks. It's much easier to replace the shocks than the springs.
Old Nov 7, 2008 | 12:17 PM
coda618's Avatar
coda618
though not reuired, if they are the original springs, I would replace them. for about 80 bucks you can get 560 rated springs from opentracker.
Does your car bottom out at all on big dips the road? If so, they should be replaced. They will make a big difference in the handling of your car too.
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
