modifing the CVR
Old Apr 12, 2009 | 12:54 AM
mortman's Avatar
mortman
try this, i still dont know if it works, having problems
Old Apr 12, 2009 | 01:25 AM
smoot's Avatar
smoot
Thanks for the quick reply.
After doing a little more investigation, I found that National Parts Depot actually sells a replacement solid state CVR (P/N 10804-1E) for $59.95. I think I'll give that one a try.
Dave K.
Old Apr 12, 2009 | 09:00 AM
JamesW's Avatar
JamesW
Buy one for 59.95 or make your own for about 5 bucks.
Free enterprise at work
Old Apr 12, 2009 | 09:29 AM
fakesnakes's Avatar
fakesnakes
Dude, the LM7805 is about the cheapest IC you can buy! Here are 50 from China for $11.00 (if you will buy from China), or go to Radio Shack and buy one for a couple dollars.
See, even I can recommend things that don't cost a small mortgage!
Old Apr 13, 2009 | 02:19 AM
smoot's Avatar
smoot
Yah, but Mortman said he didn't know if it worked and he was having problems with it.
Has anybody actually built one of these with a LM7805 and had it work okay? If so, I'll try building one also.
Thanks-
Dave K.
Old Apr 17, 2009 | 08:24 AM
mortman's Avatar
mortman
I not sure what my troubles are with my gauges - i have not worked on the car for a month, ill be back at it starting tonight ill report back once i narrow down my gauge peging problem and let you know how the mod woked out. To be honest it only took 10 minuits to build
Old Apr 20, 2009 | 08:49 AM
mortman's Avatar
mortman
Finaly figuared out why my gauges peg out, mini tac needs a piece of ruber/cork between the tac body and the gauge pod casing. any way the moded CVU did not work, i must have done somthing wrong.
Old May 8, 2009 | 02:07 AM
tx65coupe's Avatar
tx65coupe
We built ours and it works great.
Old May 10, 2009 | 12:16 AM
chris66dad's Avatar
chris66dad
http://chris66dad.tripod.com/id29.html
Here is a detailed how to article with parts I put together when I built mine. I could not find anyone who had wrote up something so I took pictures of everything when I built it
The capacitors I added are probably overkill for filtering out the noise but it was a couple of dollars and this way I know spikes wont damage the circuits. The impedance of the circuit does not require a clean signal though.
Ron
Old May 11, 2009 | 10:32 AM
TexasAxMan's Avatar
TexasAxMan
I think you may need a heat sink for longevity, that little voltage regulator will get hot. I see that you are using the old case as a heat sink, I'm just not sure that's adequate. For a couple of dollars you can get a small heat sink from Radio Shack.
