headers
Old Nov 16, 2008 | 11:16 AM
65Rocky's Avatar
65Rocky
Default headers
ok it has been talked about before but, what headers should I use in a 65 5,0 AOD transmission,alum heads, 600 CFM carb.
I what to use long try y's if I can ,1 1/2 or 15/8
and what plugs to use too
Old Nov 16, 2008 | 11:38 AM
Starfury's Avatar
Starfury
What's been done to the engine? What specific cam/heads are you running? Tri-y's are great for stock motors or those running lower rpm's, but if you're winding it up to 6k a lot, you may want full length headers.
Old Nov 16, 2008 | 12:16 PM
65Rocky's Avatar
65Rocky
It is my first build, my 289 was blown and c4 stolen when I took it out, so I got a 1990 H.O short block that was rebuilt from faster 5.0, 30 over, cam stock ?, the heads are 195 pro comp alum. all new sealed in plastic all for $1,100 from a guy in Bloomington Indianawho totaled his Mustang after he bought the parts
Then I got Roller rocker,lifters and pushrods from Ford racing, then a rebuilt AOD, no cables yet, eddy intake and 600 carb used,
low cost, I spent all my budget on the body and interior, had to replace just about everything, a real rust bucket but soild now.
distibuter is a crane cam 1601 and hi 6.
Old Nov 16, 2008 | 12:31 PM
Starfury's Avatar
Starfury
Well, how much money do you have? I'd recommend either Doug Thorley or FPA tri-y's, but they're very, very expensive. You get what you pay for, though...
Old Nov 16, 2008 | 01:00 PM
65Rocky's Avatar
65Rocky
$300 -$400 not much left, would of did it differantly if I knew about the web sit first.
not sure if the parts will work together well?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
