1988 EFI 5.0 motor into a 67'
Old Nov 21, 2008 | 04:10 PM
polo708's Avatar
polo708
Default 1988 EFI 5.0 motor into a 67'
My car currently has a 289 in it... I found a great deal on a high output 5.0L with EFI setup off of an 88 stang. What will it take to swap this to my 67? Can I keep my strut towers or do they need to be cut? Will my C4 tranny bolt up with a different flywheel? Things like this... thanks.
Old Nov 21, 2008 | 04:18 PM
dodgestang's Avatar
dodgestang
The hardest part of this swap is the wiring harness but you can buy a painless kit to do it.
The motor bolts in without mods to the shock towers.
You will need to add an e-pump and a return fuel line for the EFI
You will need to get a flywheel to match the imbalance on the motor for use with your c4
Old Nov 21, 2008 | 04:22 PM
polo708's Avatar
polo708
stock wiring harness from the 88 mustang wont work?
Old Nov 21, 2008 | 04:31 PM
JamesW's Avatar
JamesW
Take a look at my website below Brian...it's got some stuff on doing this swap
Old Nov 21, 2008 | 09:07 PM
dodgestang's Avatar
dodgestang
It will need to be modified to work. Which is a pain. My bro did this way back in 88 when he put one in his 67 mustang....it's alot easier with a built to use harness
Old Nov 21, 2008 | 09:31 PM
andrewmp6's Avatar
andrewmp6
Also the oil pans are different.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mungodrums
Sep 28, 2015 10:54 PM
treesloth
Sep 28, 2015 07:03 AM
logan409
Sep 26, 2015 07:43 PM
mrappe
Sep 26, 2015 10:16 AM
