Electrical problems/questions
Old Nov 23, 2008 | 06:38 PM
blazerdup's Avatar
blazerdup
Default Electrical problems/questions
Ok, so I admit electrical problems are not my forte. But here is my problem. My alternator dummy light keeps coming on and now my blinkers wont work. I thought it was the alternator, which was bad, but the problem still persists. Also, the voltage gauge is up and down and my tach jumps like crazy and sometimes just doesn't work at all. I replaced the voltage regulator as well and it didn't help.
I am stumped. Any advice?
Old Nov 23, 2008 | 06:42 PM
REAVER117's Avatar
REAVER117
Did you replace the voltage regulator for the alternator, or the instrument panel voltage unit? Unfortunately it could just be a short or bare wire somewhere on the wiring harness.
Old Nov 23, 2008 | 06:51 PM
blazerdup's Avatar
blazerdup
Yes I replaced the external voltage regulator because the alternator does not have an internal one. Everything has been working fine for the past year until the alternator went out. Now it is just acting wacky. I didn't see any frayed wires either.
Old Nov 23, 2008 | 07:05 PM
blazerdup's Avatar
blazerdup
Old Nov 23, 2008 | 07:50 PM
vescotech's Avatar
vescotech
If you can get your hands on a volt meter you could check the battery voltage while your gauge is acting up to verify if you have a charging system problem or a problem with the instruments.Are the turn signals not working or just the instrument indicator lamps?
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
allenmaty
Sep 24, 2015 09:17 AM
uberstang1
Sep 20, 2015 06:42 PM
TfcCDR
Sep 14, 2015 12:08 PM
