"Evil's" winter storage tips
Old Nov 25, 2008 | 01:00 PM
67 evil eleanor's Avatar
67 evil eleanor
Default "Evil's" winter storage tips
Well its that time again. Time to put our Steed in the barn for good Winters rest. It seems as Winter approaches a lot of storage questions arise. So, this is my attempt to share some storage tips that have worked for me.
#1 Environment. As you know its better to keep your car stored inside and out of the elements. A good clean garage is a great place to bed down your Horse for the winter. The ideal environment would be one that is climate controlled with both heat and humidity. But for most of us this is out of reach. The ideal humidity level would be between 40 and 60% where as corrosion all but stops (think of a Arizona car) and a constant tempature. Less than 40% promotes dryrot with the vinal and rubber. Another issue is a concrete floor. Concrete floors are great but can allow mosture to collect in the form of condensation. This will form on the bottom of your car and setup ideal conditions for rust on the unibody and reek havoc the exhaust system. A simple layer of polyethylene plastic will help keep the mosture trapped and not allow it to move up.
#2 Tempature. For those of us living in freezing areas this is an issue. The antifreeze needs to be checked with a Hydrometer or Refractometer. The Hydrometer works only on Ethylene Glycol based coolants/antifreeze and not on Proplyene Glycol based solutions. The Refractometer can be used with either and is the one I perfer. For you race car guys that are running straight water and maybe a cooling enhancer (Redline water wetter), you need to add or change over to a 50/50 solution of antifreeze. Also remember that antifreeze wears out. Over time the corrosion protection additives will weaken and the coolant may become acidic. It seems that most manufactures recommend every 30,000 miles or three years. There is a lot of room for discussion on the types of coolants (IAT, OAT, and HOAT) and their intended use. You will need to do some research on which is best for your engine build and cooling system and make your own determination. "Electrolysis" is a good indicator that the coolant is too acidic. You can check this with a volt meter and the engine running with the electrical system under full load (make sure the radiator is not pressurized). Stick one probe on the negative post of the battery and the other in the coolant. Anything over 400 millivolts means the coolant is shot and is in need of replacment. Also check the windshield washer fluid as some are not freeze proof and these will need to be drained or changed to a winter washer fluid.
#3 Fuel. This is one that is a very fix but often overlooked untill Spring when you turn the key only to be disappointed. Todays "pump gas" will start to break down in a matter of weeks. This will leade to the formation of a varnish like substance and clog your fuel system. The simple solution is the addition of a fuel stabilizer. Its only a few bucks and can save you hundreds in the Spring. Be sure to top off the tank once the stabilizer is added.
#4 Battery. This can be removed or left in. If you plan to leave it in the car, then you need to use a trickle charger to keep it healthy. Make sure to disconnect both cables from the car before connecting the charger to the battery. If you leave the cables hooked up, then you have the potiential for a source of ignition if something in the electrical system fails or is damaged by a rodent. If removed, it needs to be placed on a wood board or rubber backed carpet and not on the bare floor. Storing it in a warm location and charging it once a month will keep it healthy.
#5 Tires. For the long sleep you need to inflate the tires to the maxium listed pressure if you don't plan to use jackstands. Just don't forget to adjust them in the Spring or when you take it out of storage. It seems that most modern radial tires are not prone to flat spotting due to winter storage. If you have the old vintage or original (haha) type, then jackstands are a must.
#6 Protecting the finish. Before you put your baby away give it a good cleaning and wax job. Vacuum the inside and use some protectant on the vinal and rubber. I use WD40 on all the chrome both on the inside and outside. It will leave a film that will protect the chrome from corrosion and usually last untill spring. A car cover is a good idea also. I perfer a 100% cotton cover if stored inside a garage. If under a carport or outside, you may want to make sure the cover is secure. The wind can cause it to rub the paint off if left loose. Remember that when buying a cover, "water resistant" is not "waterproof". I see a lot of people using a water resistant cover then placing a waterproof tarp on that and using about 50 bungee's to tie it all down. This seems to work well if no indoor garage is available. The last thing is mold. I leave the windows cracked about 2 inches when in storage. This will allow some air flow and reduce the chance of mold. Nothing like uncovering in the spring and finding out the interior has changed colors.
#7 Mechanical. Cars like to be run. When we don't, they get mad and cause us trouble. Check and fill all the fluids before, during, and after the storage period. Also grease the suspension and don't forget the U-joints. When greasing the front suspension, its a good idea to have the car on jack stands. Once done, move the steering wheel back and forth to distribute the grease. With the weight off, the grease will move more freely. While the front wheels are off the ground, its a good time to look at the wheel bearings. Wheel bearing grease can dry out and cause bearing failure. While the wheels are off, take a look at the brake pads or shoes. Its a good time to change them if they are worn. Don't forget about the rear. When checking the rear brakes, look to see if theres any leakage of oil from the axle seals. Sometimes this goes unnoticed untill a problem arises. When in storage try to start your car at least once if not twice a month. When you do, bring it up to operating tempature. If only started for a few minutes and not allowed to heat up, condsation will quickly form and may cause internal injury to the engine and drivetrain. Also its a great time to engauge the A/C and work all the electrical devices. If possiable put it in gear and move it back in forth. This will help keep things lubricated.
#8 Rodents. No, not your cousin Vennie or uncle Bob, but those little furry creatures with long tails and sharp teeth. For me, I do a three step protection. It starts outsied the garage with poison bait blocks. Hopefully I can get them on the outside before they move in and cause damage. You have to be careful around other pets and children and follow the warning labels, but it has been very effective for me. The second is mouse traps. I always keep several traps baited and set. This lets me know if any of the little creatures have made it in. Also I have poison blocks in hidden locations where I think they may want to hide. The last is soap. I keep a couple of bars of "Irish Spring" in each car. I open the box and sit it in the floors. So far it seems that it works. If it don't, at least the car will smell springtime fresh when it comes out of storage.
This is what I do and there may be a better way, but so far this has worked for me.
Old Nov 25, 2008 | 02:09 PM
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
You know My Cousin Vinnie?
Old Nov 25, 2008 | 03:32 PM
NvrSumR's Avatar
NvrSumR
Thanks for taking the time to write all this out. Is it better to leave engine and tranny oil in or have them drained?
Old Nov 25, 2008 | 04:03 PM
SJs 66coupe's Avatar
SJs 66coupe
Glad I live in Houston where I don't have to go through that crap every winter :-)
Old Nov 25, 2008 | 06:38 PM
wumarshall82's Avatar
wumarshall82
I hear that. Living in SC i'll be able to drive my car once every week or 2 but def. not as much as I did because it does get cold enough where you dont want to.
Old Nov 25, 2008 | 07:20 PM
67ragtop's Avatar
67ragtop
I'd recommend you change the engine oil and filter before laying it up for the winter. You don't have to drain the transmission oil.
Old Nov 25, 2008 | 08:04 PM
andrewmp6's Avatar
andrewmp6
Or be crazy like me drive yours year round but the factory heater sucks tho.
Old Nov 25, 2008 | 08:51 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Good writeup.
It is freezing here. Damn near down in the 50's tonight.
Old Nov 25, 2008 | 09:35 PM
blue66mustang's Avatar
blue66mustang
Thanks for that.....20 here tonight.
Old Nov 26, 2008 | 05:12 AM
kalli's Avatar
kalli
just to add to the storage tips:
if freezing the antifreeze is a must. I have seen a lot of destroyed engines in my time where the water in block exanded ojnce it froze and just cracked the engine. or in more modern engines the block was healthy but when owner started it the water pump was frozen solid in the block (wouldn't turn) which ripped the timing belts and that caused the pistons to run right into the valves ... all bad. I don't understand the point in running water only in race engines. antifreeze increases boiling point and is an anti rust agent at the same time ...
turning of engine occasionally is a must as well. there are too many places where you can get condensation in building up flyrust on the cylinder walls
anyway i'm driving it as well throughout the year (we have 30-75 all year round). It';s the rain and humidity that kills cars here
