Coolant Leaking - Pics
Old Nov 27, 2008 | 04:16 PM
jonward786's Avatar
jonward786
Default Coolant Leaking - Pics
The two hoses that run to the firewall, one of them has a little device spliced into the middle of it. Coolant leaks out of there. Seen here:
First question: what exactly is it? a filter?
Second question, can i run those hoses on top of the intake or will that be too much heat?
Old Nov 27, 2008 | 04:43 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
wanna clean up your engine compartment go to the junkyard and get the coolant transfer tubes off of a 1986-1993 mustang, lincoln mark 8 etc it will run along the top of the intake from the front of the motor to the rear.
Old Nov 27, 2008 | 05:23 PM
fakesnakes's Avatar
fakesnakes
That looks like a vacuum operated heater control valve to me. Replacements are pretty cheap and that one looks like it is as old as your car. Here is a picture:
It's $19 from Summit:
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 27, 2008 | 06:27 PM
Starfury's Avatar
Starfury
I'm sure I can find you one at work, Jon:P
Old Nov 27, 2008 | 07:42 PM
jonward786's Avatar
jonward786
correction, the leak was not coming from the device itself, but the hose was cracked underneath...couldn't see it. but at least now i know what the hell it is.
anyone care to post some pics of how they route their heater hoses? id rather not have mine dangling down the side next to the headers.
Old Nov 27, 2008 | 09:01 PM
JamesW's Avatar
JamesW
As mentioned, you can use the metal heater tubes from a 5.0 to really clean up your engine bay.
Here's how mine connect from the tube to the heater core
http://www.midnightdsigns.com/Mustan...ater%20004.jpg
Old Nov 27, 2008 | 09:52 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
if your interested jonward pm me in about 4-5 days and ill look to make sure i have one. i can sell you one of the extras i have laying around. i got a few to do it on my 65 and other projects. but im out of town right now thats new.
i figure i could take maybe 15$ plus shipping
Old Nov 27, 2008 | 10:15 PM
JamesW's Avatar
JamesW
Here's my old motor, you can see how the rubber hoses run along the intake to the back. The mechanical valve was replaced with an all plastic unit that won't corrode.
http://www.midnightdsigns.com/Mustan...DSC00140-1.JPG
Old Nov 28, 2008 | 03:42 AM
4reboy's Avatar
4reboy
I had coolant leaking problems today too... I think my hoses started leaking because my car was sitting so long but it appears they have sealed up, no more leaks. Just now my passenger carpet is soaked
I really liked that coolant tube from the 5.0, if I ever go to the junkyards again with my friend I'll try to find one.
Old Nov 28, 2008 | 09:30 AM
Iskwezm's Avatar
Iskwezm
you can just buy some bulk 5/8" hose and route them how you want.U se a piece of string to see how you wnat them and then cut a little longer in case
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
