Ford Performance Solutions
Old Dec 2, 2008 | 02:49 PM
eZ's Avatar
eZ
Default Ford Performance Solutions
Went down to fps today to get a quote on my 347. The owner Troy was very helpful, good guy. Heres What we came up with;
Super comp short block 2333.10
4340 forged crank,
4032 forged pistons, srp flat top 10.6-1 w/ my heads
4340 H-Beam rods,
CL-77 bearings, Pro-Moly ring set.
arp head bolt 49.24
manley 6.400'' chrome moly
5/16 swedge end pushrods 98.00
302ho retro kit w/o lifters 54.06
ford hydraulic roller lifter 143.26
std oil pump 28.93
moly oil pump drive 18.89
dual roller timing set 47.99
frt dip stick manual fuel pump 76.99
sfi 28bal profes prod 165.77
assemble long block 200.00
canton universal dip stick 23.78
recurve dist. 52.79
custom hydraulic roller cam 245.39
canton front sump t pan 205.00
canton pickup 41.10
main girdle 175.00
grand total 3,971.29
I already have afr 185's, air gap intake, and 1.6 magnum roller rockers. He showed me dynos sheets that put this right about 500hp and 460ft lbs
Old Dec 2, 2008 | 03:29 PM
racin66coupe's Avatar
racin66coupe
nice!
Old Dec 2, 2008 | 06:26 PM
boogerschnot's Avatar
boogerschnot
Mmmmm,,, I cant wait to stroke mine.. a 408 would make me very happy...
Remember Kids: There's no Replacement for Displacement.
Old Dec 3, 2008 | 12:45 AM
Iskwezm's Avatar
Iskwezm
I dont belive 500 hp........sorry. I have basically the same combo so with my turbo i would be at 650+ and that aint happening.Troy is a good guy, but keep on him, he also did my engine 3 TIMES due to "woops" and "oh, is that what we were doing".
Old Dec 3, 2008 | 01:20 AM
350kmileFord's Avatar
350kmileFord
What are the cam specs?
Old Dec 3, 2008 | 02:39 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
check with woody at http://www.fordstrokers.com/ he has great prices
Old Dec 3, 2008 | 08:40 AM
boss_dude_429's Avatar
boss_dude_429
yea i like woody alot very easy to work with and they also do custom stuff too
Old Dec 3, 2008 | 10:40 AM
eZ's Avatar
eZ
i hear woody is great but i want to go with someone local. I told troy i want to run a xe282hr. He wants to put a custom cam in. I dont remember what specs.
As far as 500hp i dont belive it as well. but I have seen more than a few applications get close to 480hp n/a. Hp power numbers are not as important to me as the torque curve anyhow. Id be happy with 430 if it kicks *** throught the rpm range.
Old Dec 3, 2008 | 11:34 AM
Iskwezm's Avatar
Iskwezm
I think 430-450 is A LOT closer to what it will make. My buddy had them build his with a Funnel Web,AFR’s, .600 lift roller and 11:1 and it made about 475 on a engine dyno if I remember correctly.
My buddy has a CHP 9:1 347 claiming 450 HP and it is very quick, runs 7.6’s untuned and vey dependable.
Old Dec 3, 2008 | 12:07 PM
woodsy's Avatar
woodsy
Thanks for the kind words, if I can help in anyway just shout
