Ignition coil question
Old Dec 5, 2008 | 02:29 PM
Adrenolin's Avatar
Adrenolin
Default Ignition coil question
Does the distance between the ignition box / coil / distributor matter? If so which should the coil be closer to.. the distributor?
I'll be mounting the box in the cabin under the dash and it would have been nice to mount the coil here as well. Something in my head however tells me the coil should be as close to the distributor as possible. Is this correct?
Thanks
Old Dec 5, 2008 | 02:36 PM
fakesnakes's Avatar
fakesnakes
The closer the coil is to the distributor the better. This lessens the distance for the secondary which is the spark. Put your box under the dash and run the small gauge primary wires to the coil. Mount the coil on the head, manifold, or even wheel well, which ever is most convenient. Also, some coils need to be mounted with the tower pointing up. Others can be on there side.
Old Dec 5, 2008 | 03:53 PM
jlg2002's Avatar
jlg2002
+1, the shorter you keep the secondary ignition path the better. Longer coil wire = more resistance. More resistance = less spark intensity.
Old Dec 5, 2008 | 06:40 PM
my77stang's Avatar
my77stang
mine is on the wheel well and i dont even like it being that far away - but using kickass wires helps keep your losses to a minimum
Old Dec 5, 2008 | 07:48 PM
Adrenolin's Avatar
Adrenolin
I knew this.. really I did! Really
I've still got the old bracket which I bead blasted and had powder coated mirror black. I'll use that mounted by the distributor somewhere. Thanks.
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
jessicarabbit
Sep 25, 2015 12:41 PM
jaiidutch
Sep 14, 2015 10:29 AM
Wombatnation
Sep 13, 2015 09:16 PM
