Fuel flow problem/question
Old Dec 9, 2008 | 11:02 AM
runway1's Avatar
runway1
Default Fuel flow problem/question
I have 65 coupe with a 302 and when I press the accelerator, sometimes it stutters and stalls - especially when hot. It has a, soon to be replaced, stock 2bbl carb.
What's the diagnosis? Float level? Fuel pump? Mixture? Any help is appreciated.
Old Dec 9, 2008 | 11:18 AM
chappys4life's Avatar
chappys4life
Is the fuel line running close to the exhaust manifolds/headers? When fuel lines get too hot the gas evaporates. Check your fuel line from pump to carb and fuel filter would be my first start.
Is your carb leaking at all that you can see? Also does it happen when going through turns or on a hill?
Old Dec 9, 2008 | 01:28 PM
runway1's Avatar
runway1
Don't know about the turning. Actually, it's my son's car. I replaced the filter from the pump and that cleared the problem for a couple months. Now, it's back.
I'll check the fuel line proximity to the manifold. No leaks on the carb, that I can see.
Old Dec 9, 2008 | 07:07 PM
runway1's Avatar
runway1
Ideas? Is this a float problem maybe?
Old Dec 9, 2008 | 08:37 PM
Starfury's Avatar
Starfury
If you replaced the filter and it got better, your problem is likely a clogged fuel filter again. With an old tank, it's not uncommon to have a lot of crap built up that's getting sucked through the lines. Replace the fuel filter again, see what happens. If it gets better, you should consider replacing the tank.
Old Dec 10, 2008 | 08:18 AM
chappys4life
Yup what starfury said. Sounds like crap in the tank. Try a new filter, maybe a clear universal like you get at napa. If it clogs after a month or two you need a new tank. If you can afford it its a good time to change the fuel lines too. Stainless upgrades are cheap and last a long time.
Old Dec 10, 2008 | 11:36 AM
runway1's Avatar
runway1
Good points. Thanks all.
Old Dec 10, 2008 | 11:44 AM
Nick.Simonds's Avatar
Nick.Simonds
Hey runway1, you havent by chance put E85 in there have you?
Old Dec 10, 2008 | 02:04 PM
jlg2002's Avatar
jlg2002
Ruway, any chance you could do a pump pressure and volume check? ( about 15 mins work if you have the pressure gauge). This would tell you if it was supply or carb.
volume check : 1 pint in 20 secs. press 4-6 psi (both values are with the engine at idle)
Old Dec 10, 2008 | 06:13 PM
1965fastback's Avatar
1965fastback
Accelerator pump going bad?
