Changing differential fluid after rebuild.
I have about 750 miles on a rebuilt 8" rearend/differential. When I change the fluid, can I get away with simply pumping the old stuff out or will that leave metal flakes behind? Or do I really need to take out both axles and disconnected the pumpkin?
Definitely should replace the fluid, but there should be a magnet in the bottom of the case to pick up any shavings. If so, I wouldn't worry too much about simply sucking the fluid out and dumping new stuff in.
I doubt there are any metal flakes in there in the first place.
Most of the stuff is a black dust the comes off the gears. I think it could be a surface coating left on after the carburizing process. I would imagine these gears are carburized to created a hard face to resist wear but still have a softer tougher core that can take shock loading with out shattering.
I could be way off but Im betting that most of the deposits are graphite/carbon with some metal dust. Drive it around then empty the fluid and most of the stuff should be in solution when you suck it out.
Thats what I did on mine and I drove it for a few days then check the fluid and it was still yellow. The stuff that came out was black.
-Gun
-Gun
LivingInThePast
Sep 16, 2015 12:20 PM
