Versailles rearend
Old Dec 23, 2008 | 09:54 PM
vescotech's Avatar
vescotech
NC Harley where in NC are you located? If you're near Hickory stop in at Flowers Co and look in one of there old cataloges.It gives the specs on the hose you need. You can chose one slightly longer with the same ends. They have a great selection on hand. I put rear discs on my 66 off of a 99 linclon and they had the hoses I needed on the shelf.
Old Jan 3, 2009 | 04:53 AM
tx65coupe's Avatar
tx65coupe
I recieved an email back from Nick at Brake Hoses Unlimited and he asked me to call him. I had to leave him a message. I hope to hear back from him soon.
Does anyone else know where to find Versailles brake hoses for the calipers? I have searched nearly everywhere and they still show to be on backorder. Does anyone know what hose could be used in place of them? I don't want to go this route but may have to. I have also checked with several shops that make hydraulic lines etc about rebuilding my old hoses but none of them will do it.
Old Jan 3, 2009 | 07:49 AM
my77stang's Avatar
my77stang
getting them custom made will probably be the best thing, and you might as well get them in stainless while your ordering them.
i have a small autoparts store 5 minutes from me that will make any hyd. line you could ever want - that place has saved my butt a few times
Old Jan 3, 2009 | 03:54 PM
baddog671's Avatar
baddog671
Originally Posted by fakesnakes
I got mine from Currie Enterprises. Check to see if you have 3/8-24 ends for the banjo bolt and you are good to go (the other end fits standard 3/16 hard line):
I have cadillac calipers on my 9" and it uses something similar to that. But, there actually is no rubber. The brake line threads into a "block" (like pictured above), and then a banjo bolt connects the "block" to the caliper. Stupid I think, now you have 4 potential leak areas instead of 2. You can't thread the line directly into the caliper becuase line is fine-thread while the caliper is coarse thread.
Perhaps you could use a setup like this. Find out what size threads are needed.
I've always heard that although Vers. are pretty much a direct drop-in rear, the parts are obsolete. And EXPENSIVE>..
67LimeCoupe
Sep 30, 2015 04:46 PM
67LimeCoupe
Sep 21, 2015 06:34 PM
67LimeCoupe
Sep 2, 2015 08:02 AM
jhutch
Aug 19, 2004 05:57 PM
S_man_9
Aug 13, 2004 12:32 PM
