Radiator
Old Dec 23, 2008 | 11:38 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Radiator
I know this may be a stupid question, but how do you guys drain your radiator? I know where the drain is, but one of the supports is in the way and I need to save the antifreeze to put it back in the radiator.
Old Dec 23, 2008 | 11:40 PM
fakesnakes's Avatar
fakesnakes
I usually hold a 5 gallon bucket under the lower hose and pull it off.
Old Dec 23, 2008 | 11:42 PM
1slow67's Avatar
1slow67
ROTM Moderator
Do you pull it off the radiator or off the motor?
Old Dec 23, 2008 | 11:56 PM
Carlos Pineiro's Avatar
Carlos Pineiro
Either, but better from the radiator. Loosen the rad cap first.
CP
Old Dec 24, 2008 | 07:50 AM
fakesnakes's Avatar
fakesnakes
Yep, off the radiator, it's easier to get the bucket in there without hitting the oil pan (found that out the hard way).
Old Dec 24, 2008 | 08:08 AM
lunarweasel's Avatar
lunarweasel
BA,
On my 67 6 cyl, I was able to wedge a generic yellow plastic funnel in between the radiator and that diagonal support. I then put a container below that. (I was trying to keep the radiator fluid off the paint too [dont know if I needed to]). I miss that car.
Old Dec 24, 2008 | 08:17 AM
JamesW's Avatar
JamesW
You can also siphon it out of the top and get a majority out, then unhook the lower hose.
Old Dec 24, 2008 | 02:30 PM
ThongsareSweet's Avatar
ThongsareSweet
I found out the Hard way. Thought I released enough pressure but when i Yanked it off the hose was draining into the bucket but some was shooting so fast out of the rad it was a mess. Oh well its only anti-freeze haha
Old Dec 24, 2008 | 02:51 PM
1slow67's Avatar
1slow67
ROTM Moderator
I got it. I put a tube on the drain. Now all I have left is charge the battery up and I am ready to drive it around.
Old Dec 24, 2008 | 05:18 PM
ThanksDad's Avatar
ThanksDad
I have never reused or heard of anyone reusing anti freeze. At $5.00 or so a gallon its seems easier, safer and better to replace with new clean fluid.
Whats your reasoning for reusing it?
